Hi All.
Well it's time to put the boat away and I had in the water one last time today. coooool, water was 51F...
Anyways, changed the oil and filter on the 4-tec and pulled the plugs to winterize.
The coil top end has a rubber seal to keep the coil centered and debris out, the bottom inch on 2 cylinders (front and back cylinder) the rubber seal was almost disintegrated, almost like it was too hot.
(I mean the rubber part that goes into the hole)
Question 1: anybody else seen this on 4-tec or 4-tec SC ??.
Plugs, all plugs seemed wet around the bottom piece of the ceramic , and one plug has a hairline crack all the way around,all were brown at bottom of ceramic.
Engine runs 100% and plugs were tight.
Question 2: are the factory plugs any good, are the "wet" and hairline crack a sign of anything or just time to change plugs.
-Gab.
-Gab.
