So, I pull my carbs off of my 94XP that I got at the beginning of the summer. Time to do the winter rebuild. I find that this sucker has NEVER been rebuilt. All of the OEM paint is still on the carbs and they look BRAND new... Poblem though. As I start to dissassemble the carbs, almost every screw head either strips out or snaps off!! Even the two screws that holds the internal plate over the high and low jets, heads popped off. So, I have a 93SL650 that is being parted out and I still have the three carbs..... If I use the N/S and jets from the XP and put them into the Polaris carbs, make sure the linkage is good to go, and of course use the XP fuel system, pumps, plates and brackets.... It should work RIGHT?!
I don't want to spend a bunch of time trying to get out these massivly stuck little studs in my carbs, I wanna ride! Ideas?? Suggestions?
Or, anybody have a good shape carb setup for a 94XP that they will let go of for cheap?? I am open for suggestions!!
