Results 1 to 4 of 4
    Jun 2004
    Spring Hill, Fl.
    149
    Angry oil pump block off
    Ok I finally learned my lesson about the piece of *#*#@%* crap Mikuni oil pump on my ski. Now that I have to replace my rings and bore/hone my cylinder wall on one cylinder, I am ready to ditch the pump once and for all. I know about the oil pump block off kit, but my question is that on my ski, the oil is pump directly into the carbs and mixed with the gas internally, so what do I have to do to block off those oil ports on the carb? Do I have to replace the carbs or will vacuum caps on the ports suffice? Thanks, Rob
    ride it like you stole it
    Apr 2002
    SC
    64
    Default Re: oil pump block off
    the vacuum caps worked for me. secure them with a zip tie. i think they even came with the oil pump block off.
    Jun 2004
    Spring Hill, Fl.
    149
    Thumbs up Re: oil pump block off
    Thanks!!!!
    Aug 2003
    196
    you can also crimp them closed only if you never plan on installing a pump in the future.
  1. Replies: 2
    Last Post: 08-17-2005, 08:28 PM
  2. Oil Pump Block Off 99 Ultra 150
    By Tweaked & Twisted cycles in forum Kawasaki
    Last Post: 08-08-2005, 10:31 PM
  3. 94 Sea Doo spi oil pump block off
    By khall79 in forum Sea-Doo
    Last Post: 05-29-2005, 10:13 PM
  4. OIL BLOCK OFF ?
    By 97'GSXPCJ1 in forum Sea-Doo
    Last Post: 08-10-2002, 03:50 PM
  5. What to check when buying a used ski
    Last Post: 08-01-2002, 04:47 PM
