Just took ride in to a shop I have never used. They said the starter was out and needed a battery and new starter switch. Is it ok here to ask what neighborhood the cost should be? They are talking 700+
Cost to have starter replaced
Re: Cost to have starter replaced
New parts at Riva cost
GP1200 parts
Start Button (you may need more than the button) $5.39
Starter $404
Battery $50.00
Why dont you fix it yourself,if you were up here Hoffman Estates Illinois Im sure I could do it for around $400.
I have parts that I could swap to make sure you were not buying parts you did not need.
SCOTT...
hard for me to believe that both the starter and starter switch just happened to go out at the same time... I would start with a new battery first... I have seen rebuilt starters on ebay for <$200... if you feel more comfortable with a new one, buy from either Riva or Island Racing.
If you look around you can find starters for less.
I bought one for my triple piped GP this summer I had alredy fixed my old one and it just made sense.
In the part I bought a Goki starter it was a big mistake thay are made from realy cheap material.
It lasted for about 10 starts.
You can do this yourself.
I have heard about switches going bad but have not seen it myself try jumping direct to your starter from from a car battery with the car's engine stopped.
If the engine wont turn over then starter may be bad.
I am assuming that you can turn the engine over by hand and it is not seezed.
The switch can be tested with a multi meter.
Your starter relay can be jumped to test it.
Battery.
Relay.
Start/Stop switches.
Starter.
Cables a Conections.
These are all easy to test if you have time.
SCOTT...
700 DOLLARS????? HOLY CR@P!!! Man i gotta start raising prices:)
you can do the whole job yourself if you have a 10mm & 12mm wrench and a phillips screwdriver.
go with an aftermarket starter ( we stock them, much cheaper than an oem )
try a new batt first--- that you can definately do yourself in 30 seconds.
If you decide to do the job yourself and need help you can always call us and we'll offer assistance over the phone as best as possible.
i felt bad when i charged a guy 75 bucks laybor to go to his dock and put in a starter this summer on his GP1200 . best advice i can give is do it your self or find a new shop .PRIDE IN SERVICE<br /> <img src="http://www.sbtontheweb.com/images/forposts/4609/1.jpg" alt=" - " />
Whoa!!! Thats Insane. Lets Do The Math
Rebuilt Starter Approx $200.00
Labor For Starter Replacment $70.00 Thats What I Charge On Gp 12
Battery Approx $60.00
Starter Switch Approx $40.00 For The Assembly. $35.00 Labor At Most.
$405.00 Total.
Where Is The Other $300.00 Coming From? I Wonder What Their Markup On The Starter Is. Dont Pay The High Dollar Cost Of A New Oem Starter. You Can Even Get Your Starter Rebuilt For Under $200.00 Also. I Have Them Done All The Time At A Local Starter Alternator Shop For Around $125.00 If The Armature And Housing Is Good. This Includes The Brush Assembly And Bearings And Or Bushings Replaced And New Seals. Good As New. I Would First Replace The Battery And Check The Start Switch. An Easy Do It Yourself Test. $700.00 Way Too Much. Its These Kind Of People That Take The Fun Out Of Pwc. Good Luck.WATERCRAFT SERVICES. PROVIDING THE RESIDENTS OF HOUSTON AND SURROUNDING AREAS WITH QUALITY WORK ON THEIR PWC AT A FAIR PRICE.
Oh My God. $700.00. These People Are Nuts. I Just Had The Starter And Batt Replaced On My Wifes 2000 Yamaha Xl 700. $310.00 Parts And Labor. Thought That Was Fair. I Purchased A New Battery Also $57.25. I Would Tell These People Who Are Trying To Rip You Off To Get A Life. They Are Insane. Dont Pay It.
$700.00 must be the majic number for people taking advantage of you. 10 years ago i had a VXR which needed a new intermediate shaft. i was just getting into the sport again and didnt know better. this shop in jacksonville (which is out of business now) charged me $700.00 to replace it. it wasnt untill a few years later i realized i was taken advantage of. the same goes for the dealer winterizing your ski. $50.00 to fog the motor....come on.
you cant find a dealer to charge 50 bucks to winterize lol most charge over 100 bucks .
i charge 65 to winterize . that includes fog,antifrezze,grease,battery charge , few other things . and i feel bad takin 65 bucks for it BUT for the people who want to be sure things are done right OR are to lazy to do it them selfs thats not a bad price .PRIDE IN SERVICE<br /> <img src="http://www.sbtontheweb.com/images/forposts/4609/1.jpg" alt=" - " />
Thanks again.. all... I'll be visiting with the shop Monday evening. Probably will just bring um both back home and think on it. I can always take it back if I need to. There is a dealer close by... I'll be giving them a call as well...
Thanks again. This is a super site... Next time I'll be here first..!!! :D
the starter and relay you can do your self . if no guages come on and or you do not get a click when you hit the start button you have a bad relay { very commin on yamahas } if you get a click but no crank your starter is prob bad . very easy to figure out what and how to fix , just poat and get all the help you need .PRIDE IN SERVICE<br /> <img src="http://www.sbtontheweb.com/images/forposts/4609/1.jpg" alt=" - " />
:o Once again, thanks all for the advice... Called the shop, I'm going over Wed. night to pick both waverunners up. I owe for 30 min. on each waverunner, and a winterize on the 1200... course how do you winterize with no starter?????
Thanks again for helping a newbie.... I'll be back later for the tips on the starter replacement.... :D
