Im moving to FLA and was wondering is it ok to run jet skis in the water does it hurt them any...and do u need to do anything to them after riding them in salt water?
Salt Water
Re: Salt Water
well they run best in the water :-) so ya run them in the water when you get to FL
just rember when your done riding to flush them on a hose and spray CRC or WD40 or a good oil on the motor and around the carbs also grease the fittings now and then . if you want to do a really good flush job now and then get saltaway .PRIDE IN SERVICE<br /> <img src="http://www.sbtontheweb.com/images/forposts/4609/1.jpg" alt=" - " />
Re: Salt Water
In addation to the extra care you need to take with the ski, don't forget the trailer. It will be just as suseptable to saltwater damage as the ski, maybe more so. Be sure to rinse the trailer well after each dunking in saltwater and keep all the moving parts lubed and protected. Be sure the bearings are well greased and sealed too.
DaveAny technology, sufficiently advanced, will appear as magic.
Re: Salt Water
to ad to the trailor post , if you own a steel trailor sell it and buy a galvinzed trailor . i would think a lot of freshwater guys will have a steel painted trailor , it wont last a yr in the salt .PRIDE IN SERVICE<br /> <img src="http://www.sbtontheweb.com/images/forposts/4609/1.jpg" alt=" - " />
