Is it possible to eliminate the 'Yamaha' rooster tail? When the kids are tubing the rooster tail gets them right in the face. I would think that it would be as simpel as installing a 90 degree fitting where the water for teh rooster tail comes out of. Would this hurt anything? Does anyone make a fitting that fits in & does not restrict flow?
Eliminate the 'Yamaha' Rooster Tail
Re: Eliminate the 'Yamaha' Rooster Tail
Originally posted by YamaHPFunny, you want to take yours off to keep it out of your kids face, and I want a longer hose on mine so I can shoot my kids in the face (and anyone else who I think needs it)2004 Yamaha FX HO
I solved the problem with a small ball valve placed in the hose. I actually replaced the hose with a plastic high pressure air hose to save the original Yammy hose.
I used a couple of zip clip blocks (like they use inside the ski to hold zip clips) to hold the hose steady against the hull.
Now I can have the rooster tail on or off at the flick of a small valve lever under the rear deck ...
I have a pic I can send to someone if they could post it in the thread ?
AnthonyYamaha 05 FXHO Cruiser - 100.5 hrs
