I have a 1999 Ultra150 that damaged number 3 rod journal and cylinder to what looks like a lack of lube. The maintenance manual states how to test the oil pump for flow into an open container. Is there any way to check that oil is actually making to each cylinder through each carb. If you blow on the oil port on each carb they fell blocked. I was told to put a 50:1 mix in the fuel tank then put a small bubble in each lube line near the pump then run engine to see if the bubble moves down the line into each carb. That does not sound very high tech. Is there a better way? I have a new oil pump to install on my new SBT engine but would like to insure that lube is making it into each cylinder.
Thanks,
Ed
Thanks,
Ed
