Results 1 to 4 of 4
Thread: SXIpro jet pump
    Nov 2004
    Cornwall, England
    24
    Default SXIpro jet pump
    The pump on my ski appers to be of the axial variety i.e strait throught with no taper. This differs to my old 550 which has a mixed flow pump i.e tapered, which is good as you can shim the impeller back to close the gap. Is this standard on the 750 or has my ski been altered at some point, I know conical pumps are good for flat out speed so if he raced it he may have made this alteration. If I order a new jet housing, which form will it come in?
    Aug 2001
    Spokane, WA
    417
    Default Re: SXIpro jet pump
    They started using axial flow pumps on the 650sx.. It is the same pump on all 650 - 800cc kawis, except the 750 ZXI.
    Nov 2004
    Cornwall, England
    24
    Thanx wolf I apreciate that, so I take it if I buy a new pump housing I need a new impeller with it. Either that or machine down my housing till it's smooth, then build up my impeller and turn it down in a laithe until it's tight in the housing, what da ya recon?
    Aug 2001
    Spokane, WA
    417
    Buy the new housing, then if your prop needs work, send it to Dave at Impros.
  1. jet pump humming. Bad Bearings?
    By toughwaters in forum Sea-Doo
    Last Post: 06-06-2007, 08:23 PM
  2. Repainting the Jet Pump?
    By 96gsx in forum Sea-Doo
    Last Post: 10-17-2005, 01:59 PM
  3. Replies: 3
    Last Post: 07-28-2004, 07:31 PM
  4. 1995 750 ZXI Jet pump
    By jsp in forum Kawasaki
    Last Post: 07-08-2004, 11:50 PM
