is there a problem with using a flame arrestor cover off a 93 650 WRIII on a 93 waverunner LX650, the screw holes line up but it looks to be a bit taller from the diagrams ive looked at. Will this lean me out and cause damage or does it not matter at all other than needing taller screws????
93 WR stock flame arrestor cover question
Re: 93 WR stock flame arrestor cover question
The cover itself wont cause you a problem it is the base, the stock flame arrestor base is (bent..leaned ..angled) towards the inside of the ski on the LX, to clear the edge of the hull,the WR3 is not ,you might run into a clearence fit, it WILL go on there but when a K/N was installed the hood would rub on the filter slightly when you close the hood.
