Hello,
I have a used 1994 Polaris SL 750. I took it in to be looked at, and the service people said that my problem is due to no compression in the first cylinder. I wonder if this is due to the fuel pump problem that affects this model (it needs two pumps, but mine only has had one). Do I need to buy a rebuilt engine from you if I ever want to ride this thing again? Or do you think i can fix this, depending on the damage with some mechanically inclined friends. Thanks,
Andrew
Andrew
