well while at a local boat show on my break during rebuilding my ski.. I saw a 2004 RXP brand new leftover. I bought it for $8,900 before tax.. Im **** excited for this ski but have a question, I once read somewhere that they had a problem with some zip ties falling off the inside of the hull and causing the ski to sink. Should i fix this and where and what do i have to do?
2004 RXP leftover
Re: 2004 RXP leftover
Originally posted by dontcare4urshytwell while at a local boat show on my break during rebuilding my ski.. I saw a 2004 RXP brand new leftover. I bought it for $8,900 before tax.. Im **** excited for this ski but have a question, I once read somewhere that they had a problem with some zip ties falling off the inside of the hull and causing the ski to sink. Should i fix this and where and what do i have to do?IF YOU LIKE IT.......IT MUST BE GOOD
the zip ties in question secure the bailer lines to the thru hull fitting - you can use a worm clamp or something similar.
Item 44 is what I believe you are referring to http://69.60.104.141/cgi-bin/mivavm?...Code=SE04RXPHU
It would take a couple of things to go wrong for that to happen but I suppose anything is possible
