Results 1 to 9 of 9
    Jun 2002
    Argentina - Buenos Aires
    23
    Angry 2005 NEW GP800R - Difficulty to ignite
    Difficulty to ignite. I have a new GP800R with 5 hours of use. I have
    many difficulties to ignite it. Somebody knows some trick or reforms
    so that the ignition is to faster????? Thanks
    ArielARG
    May 2003
    Houston, TX
    372
    Default Re: 2005 NEW GP800R - Difficulty to ignite
    I think our South American friend is saying that his new GP800R with only 5 hours on it is hard to start.
    Does it make sense to install a primer kit on that ski?
    "Helping you make smart choices about your money - so you can live a better life."
    Aug 2004
    Olympia, WA
    3,629
    What about a good load test on the battery??
    Dan Solie -
    04 RXP (the "Instigator")
    94 xp (freestyle mods)
    95 xp (faster than the 94)
    Jun 2002
    Charlotte NC
    1,868
    The carb had accell pumps in them try this.
    1. Turn on fuel
    2. Full choke and turn engine over for 5 sec.
    3. Now pull throttle all the way in three times.
    4. Release the throttle and try to start for 5 sec.
    5. You may have to crack open the throttle a little to get it to start.
    If it does not start do steps 3-5 again.
    Feb 2001
    Texas
    869
    Personally if it were my ski, I'd go with a primer. They fire right up! :)
    Texas Team Yamaha<br />#519 Novice <br />Region 5<br /><br /><a href="http://texasteamyamaha.com" target="_blank">Texas Team Yamaha</a>
    Aug 2002
    94
    If you're not mechanically-minded, just get a can of starting fluid at an auto store. On top of the air box, there is a little rubber plug, that's where you squirt it in. Give it a 2-3 second blast, and "caress" the throttle as you crank. It'll light right up! And once it's started that first time, for the rest of the day, you just need to squeeze the throttle fully a couple of time, and again "caress" it lightly while cranking. 'Works like a charm.
    If it doesn't fire up in 3-4 seconds, stop cranking, spray it again. If necessary, have a friend help you, and spray bursts while cranking.
    Gigi
    No more Jet-Ski's for this boy...
    Jun 2002
    Charlotte NC
    1,868
    I have heard bad things about removeing the choke plates and putting a primer kit on the 800PV engine.
    Anybody else?
  8. #8
    Jan 2002
    Jefferson City, MO
    680
    I realize he may not be near a dealer, but guys this is a brand new machine - shouldn't he be taking it back to where he got it to tell them something's wrong before tearing into it and replacing parts, adjusting, etc???
    Again, maybe a dealer is not available thus my suggestion is not feasible? Just a thought.
  9. #9
    Jan 2002
    586
    I agree with PRO. Something is wrong. Also, I've heard starter fluid should not be used on a 2 stoke. Installing a primer kit on carbs with an accelerator
    pump makes no sense. Just sqeeze the throttle 2 or 3 times and it is primed.
  1. GP800R performance parts?
    By SmokeDog in forum Yamaha
    Last Post: 08-10-2006, 08:40 PM
  2. 2005 GTX Maintenance Manual
    By jimraab in forum Sea-Doo
    Last Post: 06-16-2005, 09:07 AM
  3. Max Speed Gp800r 2005
    By ArielARG in forum Yamaha
    Last Post: 01-11-2005, 04:30 PM
