Page 1 of 2 12 LastLast
Results 1 to 10 of 18
    Feb 2005
    Lancaster, Ca
    15
    Default Water Flooded Engine
    Hey guys,
    Last summer, on my third trip out on the lake with my brand new sea doo...It was upside down for about 5 minutes and have water in the engine. I tried to start the engine in the water and no luck. So I dock the sea doo and dry out the spark plugs and it cranked right up like a champ. I ran the sea doo for at least 6 hours all day long and also the following day.
    Should I be concerned about rust in the engine? Perhaps running it all day long dried out the water?
    I am anticipating the upcoming bikini season and want to make sure my sea doo is in working order. I was able to start it up yesterday without much effort.
    Thanks in advance buds. :):D
    Jun 2002
    Charlotte NC
    1,868
    Default Re: Water Flooded Engine
    Running it for six hours should have expeled any water that was in the engine.
    You should of had it fogged before you put it up for the season.
    You should always fog a motor that will not be used for a few weeks. It only takes a min. at the ramp when you pull them out.
    Mar 2004
    Bright, Indiana
    375
    Is it possible to fog a motor at the ramp? How?
    "I'm doing the best that I can according to my current awareness!"
    Feb 2005
    Lancaster, Ca
    15
    Hi, thanks for the info/good news.
    But what is fogging? And the fact that I didn't fog the sea doo, does it mean the engine is corroding from the inside?
    Mar 2004
    Bright, Indiana
    375
    Fogging is a type of lubrication that is sprayed through the air intakes on the carbs. It lubricates the bearings in the lower end of the motor. It helps to prevent rust formation caused by condensation or excess water when the ski is stored. Some say that the ski should be fogged after every ride.
    Typically the ski is started and running on the flush kit. Depending on the type of ski there usually is a hole in the flame arrestor that allows you to shoot the fogging oil directly into the flame arrestor/air intake area of the carbs. You need to spray the oil for about a minute and need to keep the ski running with the throttle as the oil will tend to bog down the ski.
    Feb 2005
    Lancaster, Ca
    15
    Now i am skeching. That fact that I didn't fog the sea doo, does that mean rust is probably in my engine?
    Jan 2002
    586
    Just my opinion. If you ride in fresh water - NO. Salt water - maybe
  8. #8
    Feb 2005
    Lancaster, Ca
    15
    If I go to an autparts store and ask for fogging oil, will they know what I am talking about or will they give me a weird look?
    Any brands that you guys recommend?
    Thanks again, this forum rocks!
    XTMSports, because life is short!:D
  9. #9
    Mar 2004
    Bright, Indiana
    375
    Yes. Depending on what type of ski you have, 2-stroke or 4-stroke that is the type of fogging oil you need.
  10. #10
    Nov 2003
    Glendora, CA
    6,846
    They will give you a wierd look. But if you go to a boat store, they should know what you are talking about.
  1. water in engine please help
    By chingonejo in forum Sea-Doo
    Last Post: 03-11-2007, 10:54 PM
  2. Replies: 0
    Last Post: 01-05-2007, 03:04 AM
  3. engine sucking up water
    By postransformation in forum Polaris
    Last Post: 06-04-2006, 09:58 AM
  4. New Engine Water Locked!!
    By mestre in forum Sea-Doo
    Last Post: 05-07-2006, 02:23 AM
  5. Replies: 3
    Last Post: 07-28-2004, 09:19 AM
