96xpaz,
Yes there is a difference. The silver motors came in the 97 and later models SPX. Besides the oil plug hole for the counterbalancer, there is an updated and stronger counterbalancer shaft, ignition pickup and front flywheel.
Bill O'Neal WCM
96xpaz - I'm sorry if I didn't understand your question correctly - you have this under Questions about SBT, and I assumed you were only referring to our engines. Bill is correct as to OEM engines. Our engines are built to the latest updated specs.
