I have started taking carbs apart on 1994 xp and am having the most trouble getting screws out I finally got into the carbs and now cant the 2 screws holding the fuel manifold plate off I got one screw on one side off and the other the head started to strip any suggestions or should I just not worry with removing them.
1994 xp Carb rebuild problems help...
Re: 1994 xp Carb rebuild problems help...
Those are tapered head screws. You have to put the driver in then hit it with a hammer to loosen them before turning. Yes it's important to change the check valve on the other side of the plate.SBT Tech Support is here to help with your problems.
Use a Dremel tool Carbide cutting wheel and cut a slot in the Screw Head.
Soak the screw area in PB Blaster for a least (2) hours, then use a blade screwdriver to remove. In the last resort,, heat the screw head with a propane torch.
Dont even attempt to drill it or use an EZ-out, you will be sure to damage the tiny threads.
Replace the screws with SST socket head screws from www.mcmaster.com
I believe those Mikuni screws are 5mm standard metric thread but check 2BSure
(or you can send your Carbs to me for a complete rebuild // refurbish using genuine Mikuni parts and 18-8 grade Stainless Steel fasteners)
DvD
obsshn@mindspring.com
if you have already striped them , use a drill to drill off the head of the screw . the body will come right out then you can turn the studs out and get new screws . { if you get the screws first you will know what size drill bit to use } you want one the next size up from the shaft of the screw and only go as far till the head spins off .
if you have not striped them out yet use the right size impact driver and they should come out easy as said above .PRIDE IN SERVICE<br /> <img src="http://www.sbtontheweb.com/images/forposts/4609/1.jpg" alt=" - " />
