2002 GTX DI 12V Low Alarm
I'm having the same symptoms my friend had with his 2001 GTX DI and after he spent $800 on a stator installation only to find out it was the easy to install $125 voltage rectifier/regulator. This was all dealer installed and it was more than apparent they really had no clue what they were doing.
When my 2002 GTX DI started with the same problems I purchased the SeaDoo repair manual (to avoid that same dealer nightmare) and the stator and rectifier tests are all within spec. The only test I can't perfom is the amperage test (don't have a meter for that).
When I get the 12V Low error code the ski will eventually go into the limp home mode with the beeping. After clearing the code and by holding the "Mode" button for 5 seconds and then "Set" it might run for weeks with no sign of any low volt problems. Other times it will code out repeatedly and eventually stop coding with no sign of any voltage problems of any kind. The battery never dips below 14.5v and all looks OK with it. This code is just out of the blue for no apparent reason.
My question is are these rectifiers unstable and prone to failure?
Should I just go out and buy a new (prone to failure SeaDoo) rectifier?
Thanks!
Thanks!
