Same Ole Fuel Guage Problem
  • Same Ole Fuel Guage Problem
    I Recently Purchased A 98 GP1200R And The Fuel Guage Shows And
    "beeps" That There Is No Fuel When The Tank Is Full. I Have Been
    Reading The Forums And It Seems The Problem Is The Float. What
    Part Do I Need To Get To Fix This? Thanks
    Re: Same Ole Fuel Guage Problem
    Order a new fuel sender unit (the part that fits down in the gas tank).
      Todd,
      If you need help testing and repairing this...email me and I can tell you how to test and fix yours if your semi crafty.
      Mike
        THANKS, IT'S GETTING ABOUT THAT TIME TO GET WET HERE..
          Originally posted by Mpeavler1
          Todd,
          Mike
          THANKS, I WOULD REALLY LIKE THE HELP. I CAN DO A GOOD BIT OF
          MECHANIC WORK, BUT IT DOES HELP WHEN SOMEONE ELSE HAS ALREADY
          DONE THE SAME JOB..I STILL HAVEN'T FIGURED OUT HOW TO MANUVER
          ON THIS WEB SITE TOO WELL, SO IF I NEED TO EMAIL YOU DIRECTLY
          LET ME KNOW YOUR ADDRESS AND I'LL DO THAT.. THANKS
            Todd,
            Click on his name and it will open his email address.
              Todd,
              Instead of spending $100+ for a new sending unit, buy a Polaris replacement float, part number 2872860. It retails for around $23.
              David B. Thomas<br />Blew-By-You PWC Services<br />93-A Pine Burr Rd<br />Lumberton, MS 39455
                How are you sure his float is bad? The most common problem with the fuel sending units is two things.
                Plastic keeper screw came out allowing the float to make it's way into the tank..."plastic screen attachted to his craft"
                A bad resister...and or fuse. Usually it's the ver last resister that is bad. They go in increments of this for a gp1200
                R1 100
                R2 150
                R3 200
                R4 250
                Test each contact point with your float above each contact with a contnuity tester and ensure that each one works....also test the 1/2 fuse at the top...they go bad from time to time. Yours should test full 0-8 ohms....and empty is 700ohms I think...been a while....but it's up there.
                Mike
                  Originally posted by Bill O'Neal2
                  Todd,
                  THANKS
                    Originally posted by pwcskier
                    Todd,
                    THANKS, THAT SOUNDS ALOT BETTER THAN THE $100+..
                      Where exactly is that fuse you're referring to?
