hull epoxy
  • hull epoxy
    O.K. my jet ski set for awhile before I got it going again but now I haveing a problem with epoxy the factor used to attach things in and around the hull. there is a flange that is epoxyed in the hull and it let go it is around the drive shaft there is no way to get to it and I need to know how to fix the problem what can I us to reattach this (thing) back in the hull so the water will stop getting in also has any one else had this problem thanks mike :(
    Re: hull epoxy
    I found the problem after doing a search on this problem but now I need to find out how to re attach the fitting back in the hull what kind of apoxy
