I have a 2003 GTX supercharge all stock ski seems to have a cavitation problem on the bottom end and midrange. prop and wear ring look good, clearence aproximently 10 to 20 thousand looking through jet pump.
2003 GTX sc cavitation problem
Re: 2003 GTX sc cavitation problem
I believe you can buy an upgraded seal from SD. If I'm not mistaken, they changed them for the 2004-2005 supercharged models. If not Rotax racing sells them at 416 745 1044
The carbon seal is located right behind the motor under the driveshaft cover.Bill O'Neal <br>
Originally posted by Bill O'Neal2I believe you can buy an upgraded seal from SD. If I'm not mistaken, they changed them for the 2004-2005 supercharged models. If not Rotax racing sells them at 416 745 1044
