Impeller shaft question
  • Impeller shaft question
    I have a very slight groove on the impeller shaft where the shaft rides on the outer bearing ( seal side ). I replaced that bearing and sanded groove mark with 800-grit sandpaper, then buffed smooth. Will this be ok, or does this require replacing the shaft? I can post a pic later today if that would help to answer this.
    Re: Impeller shaft question
    when you pressure test the pump after assembly if the groove is an issue it will leak .
      I should point out that the groove is not ware the seal is, but within the oil chamber ( at the outer bearing ) so this would not affect the pressure test.
        sorry i see that now after re reading your post.
          I beleave your talking about the caged roller bearing it should be a nice fit and you probably dont want exsessive clearance there so it becomes a jugment call without seeing it in person.
            But it will ( or could ) allow the shaft to wobble and quickely ruin the seal.......
              I made sure I only sanded and buffed the groove itself and not the surounding area. About 1/8 inch.
              Thanks for your replys. I guess I'll run it for a few hours then pull and inspect.
                You will only need to remove the cone and check to see if water got into the pump. The oil will be milky looking.
                  if your going to blow it up just keep in mind i will be going to FL on the first of june to about the 9th , blow it up before or after that date lol
                    I only blow up motors, not jet pumps, at least so far ;)
                    Have fun in FL
