I purchased a silver Sea-Doo 951 complete engine from SBT, and had a rod failure at approximately 5 to 7 hours. After break in I added my after market head (50cc-165Psi), and Bill O's jet, and flame arresters. The rod failed at high rpm approximately (6900 RPM). The failure was not from water ingestion, or lack of lubrication. It was a rod failure “period”. I was approximately 3 months into the warranty period. I made the decision to add the performance modifications that voided the warranty. In most cases mechanical failure happens in the first few hours of operation so I thought I was safe. I did not wait long enough. I asked SBT if they would do something for me. They did not. So I learned from the mistake and purchased a rebuilt engine from Rotax for $1365.00, and an additional $300.00 for core deposit from Perry Performance Group. I added my modifications, and the new engine has 10-15 hrs on and is running perfect. You know the old saying “you get what you pay for”.
You know SBT will remove this post ASAP. They remove all negative posts. They should let the consumer read all posts negative or positive.
