I may be coming up on rebuild time on my SBT short block. I noticed when I got it last year that the case halfs were clearly not an original mating pair.
I know that OEM is a machined pair. I now have some concerns about spendng alot of money on a new crank/bearings etc on a questionable case.
(FYI my first SBT shortblock looked like a matched pair, but threw a rod. The warranty block that was sent as replacement is the one in question)
Does SBT do a new line bore (or similar process) on the cases? Will standard OEM bearings work on this case?
Thanks very much, Scott
