Results 1 to 2 of 2
    Feb 2005
    Columbia, TN
    25
    Default Need info on STX-R steering cable adjustment
    I recently installed a pump wedge on my 03 STX-R and this threw the steering cable length a little out of adjustment. So when the ski is going straight the bars are turned to the left a bit. The adjustment at the nozzle is already screwed in almost all the way and I'd have to cut the threaded shaft off the cable there to let it screw in further and hopefully get the adjustment I need. I also looked up under the handlebars and saw there may be a little adjustment there. While looking up under the bars I saw that there was a hole with nut welded up under it about an inch away from where the stud that currently connects to the steering cable. So it looks like I could remove the stud and move it over to the other hole and possibly speed up the quickness of the steering. That's what I presume anyway. I was wondering if anyone has relocated that stud to the other hole and if there is some other way to adjust the steering cable to make it work well with a pump wedge without having to cut off the end of the threaded cable? Thanks much in advance.
    Ben
    Aug 2004
    St. Louis
    236
    Default Re: Need info on STX-R steering cable adjustment
    I had a smiliar problem when I installed my UMI system on my Ultra. If I remember correct there is no adjustment on the steering shaft from the bars. I had to grind about a .5 inch off my Ultra's shaft. Are there threds left on the shaft, and the EyeHole is just bottoming out? If you have a dye you can grind it down and reshape the threds.
    Paul
    2001-Level 2 Ultra 150
    2002-1100STX DI
    2004-15F
    2002-30' Baja Outlaw
  1. Need help removing steering cable on 96 XP
    By 96xpcollegeville in forum Sea-Doo
    Last Post: 06-05-2009, 12:40 PM
  2. 96 XP Steering Cable
    By dntno2 in forum Sea-Doo
    Last Post: 05-22-2008, 11:06 AM
  3. Need to Lube 2003 GTX SC Steering Cable
    By njseadooer in forum Sea-Doo
    Last Post: 05-16-2006, 01:35 PM
  4. Steering Cable assembly WR500
    By Ray Dykes in forum Yamaha
    Last Post: 03-30-2005, 07:04 PM
  5. ZXI 1100 Steering cable
    By dank in forum Kawasaki
    Last Post: 09-10-2004, 10:49 PM
