I am currently debating between ski's. I like the Honda Aquatrax F-12X. Can anyone that own this give me some feedback on it. Thanks.
Thoughts on F-12X
Re: Thoughts on F-12X
the stock F12x-R12x makes 13 psi boost. I get 208hp with 18psi and my Sg1 kit.
I have a Stg3 F13x (1300cc) pushing 312hp with a large turbo and hand made intercooler. everythig from the injectors,ECM,rods,pistons,cams,vavles,head alot more i've changed to make that kind of Dyno tested power. not a internet guess as you see people toss around.
if i could only have one personal ski (i got 2) it would be the F12.
and i've had over 166hrs on my F13x. there very well built ski's
If i got to understand, Please don't bother to explain<br /><br /><a href="http://www.garrigans.com/topfuel/" target="_blank"></a>
Speeds numbers is not my thing as its too subjective to conditions. I build the horsepower, which is measured on a engine dyno. But the Stg 1 Kit on a stock R12x will pull 68.3 @ 6820RPM and a F12X will do 65.4 @ 6610 RPM
Both, riding normal (no superman) and about 1/3 of a tank. Flat water, not glass.
All my Skis/Kits run on 92 pump gas..If i got to understand, Please don't bother to explain<br /><br /><a href="http://www.garrigans.com/topfuel/" target="_blank"></a>
