Results 1 to 6 of 6
  1. #1
    Joined
    Apr 2005
    From
    Fairfield
    Posts
    5
    Default Thoughts on F-12X
    I am currently debating between ski's. I like the Honda Aquatrax F-12X. Can anyone that own this give me some feedback on it. Thanks.
  2. #2
    Joined
    Apr 2005
    From
    Fairfield
    Posts
    5
    Default Re: Thoughts on F-12X
    Also does anyone know what the max boost is on the turbo? How much can the motor handle? If I end up getting this ski, I want to know how much potential it has.
  3. #3
    Joined
    Jul 2004
    From
    Saint Louis, Missouri
    Posts
    146
    You need to talk to NitroShark. He has done some amazing stuff with the Honda PWCs.
    Nitro?
    -Bill
  4. #4
    Joined
    Aug 2003
    From
    a guy that uses Nitro
    Posts
    27
    the stock F12x-R12x makes 13 psi boost. I get 208hp with 18psi and my Sg1 kit.
    I have a Stg3 F13x (1300cc) pushing 312hp with a large turbo and hand made intercooler. everythig from the injectors,ECM,rods,pistons,cams,vavles,head alot more i've changed to make that kind of Dyno tested power. not a internet guess as you see people toss around.
    if i could only have one personal ski (i got 2) it would be the F12.
    and i've had over 166hrs on my F13x. there very well built ski's
    If i got to understand, Please don't bother to explain<br /><br /><a href="http://www.garrigans.com/topfuel/" target="_blank"></a>
  5. #5
    Joined
    Aug 2004
    From
    St. Louis
    Posts
    236
    Nitro, how much would it cost for your stage 1 kit? Is it pump gas safe? What kind of speeds did you see with this on a F12X?
    Paul
    2001-Level 2 Ultra 150
    2002-1100STX DI
    2004-15F
    2002-30' Baja Outlaw
  6. #6
    Joined
    Aug 2003
    From
    Posts
    27
    Speeds numbers is not my thing as its too subjective to conditions. I build the horsepower, which is measured on a engine dyno. But the Stg 1 Kit on a stock R12x will pull 68.3 @ 6820RPM and a F12X will do 65.4 @ 6610 RPM
    Both, riding normal (no superman) and about 1/3 of a tank. Flat water, not glass.
    All my Skis/Kits run on 92 pump gas..
Thread Information
Users Browsing this Thread
Similar Threads
  1. Interesting warranty thoughts....
    By Tippy in forum Questions about SBT
    Last Post: 01-02-2008, 02:18 PM
  2. Looking at buying a 94 SP Thoughts?
    By Chris07 in forum Sea-Doo
    Last Post: 06-16-2005, 01:24 PM
  3. Pro's cons or thoughts.
    By Captcasey in forum Kawasaki
    Last Post: 06-03-2005, 12:58 PM
  4. What are your thoughts Level 1 DI Kit
    By csteege in forum Sea-Doo
    Last Post: 05-19-2005, 12:54 PM
  5. Thoughts on the 2005 Yamaha FX
    By azncbr in forum Yamaha
    Last Post: 04-22-2005, 11:40 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
