Results 1 to 5 of 5
    Jun 2004
    Ks
    111
    Question ZXi primer install
    My instructions for the primer kit say to tap into the reserve fuel line, but I have only found three lines: vent, fuel supply, return. Should I tap the fuel supply line instead?
    Also, the primer itself looks too big to fit where the choke was. I though I saw somewhere a smaller plunger you could buy?
    Tom.
    Jul 2005
    MN/WI
    29
    Default Re: ZXi primer install
    ttt
    21,545
    If you only have one supply line yes you have to tee in there. Bore out the choke hole to fit.
    Jun 2004
    Ks
    111
    I ended up tapping into the fuel supply line before the filter. The only thing I've noticed it the fuel won't stay in the line between the tee and the plunger. I have to pump the plunger several times in order to get fuel to it then eventually to the carbs.
    As far as the plunger installation, I didn't feel there was enough room inside the original choke pull area to install the very large primer plunger. I built a bracket and installed it in the storage area below the clock. Now I wished I'd kept the original choke cable to fill the hole left. :(
    Jul 2005
    MN/WI
    29
    I'm by no means an expert, but if the fuel isn't staying in the line to the primer it means the primer must be leaking. Being tapped into the main line, I don't think you want to be leaking air into the fuel, thats the carburators job.
    I ended up tapping into the return line. It has its down sides, but the pluses seemed to outweigh them for me.
  1. 95 zxi 900 installed primer wont stay running
    By chase73 in forum Kawasaki
    Last Post: 07-18-2006, 07:09 PM
  2. Prop install 1996 ZXI 750
    By crwdsm in forum Kawasaki
    Last Post: 03-27-2006, 09:53 AM
  3. Replies: 6
    Last Post: 09-24-2005, 07:36 PM
  4. zxi primer kit
    By jcasey in forum Kawasaki
    Last Post: 07-05-2005, 03:25 PM
  5. Primer install on 99 XP
    By meschulz in forum Sea-Doo
    Last Post: 07-03-2005, 10:45 AM
