I just did a top end. Battery tests good, starter tests good(but was not tested under a load). It will crank good with plugs out, have to fight to get it to crank with plugs in. I have gone over all electrical connections. Today i disconnected the starter wires and jumped the starter directly from a non running vehicle, it did the same....would not crank over. It will crank with the plugs in but i have to continuosely hit the start button, but eventually i can get it to crank with the plugs in until i kill the battery. The motor sounds good when cranking over, but yet to get it started due to what i believe is a worn starter. I have good spark. Does this sound like a worn starter? Or could this be something else? Any other ideas much appreciated before i drag it to the dealer.
