Results 1 to 6 of 6
Thread: water leak
    Apr 2003
    21
    Default water leak
    I have a 98gsx limited and I wastaking on water bad last year(about 1/2 the hull in 5 minutes). I have ran it on the hose and nothing leaked, but I put water in the hull and had a steady stream running out around the driveshaft. Would the leak get worse when going across the lake?
    Feb 2005
    Lay Lake,Alabama.
    165
    Lightbulb Re: water leak
    Check your Carbon seal..
    If you knew,then you'd know!
    Jul 2004
    Atlanta
    267
    Default Re: water leak
    What bustoff said.
    You really want to get that fixed. Nothing like sinking your ski to ruin a good day, not to mention the motor.
    Any technology, sufficiently advanced, will appear as magic.
    Jul 2004
    Ft Worth Tx
    1,095
    Definitely the carbon seal needs replaced pull the pump and drive shaft fix the seal put it together and go riding worry free.
    Feb 2003
    Chandler, AZ
    35
    I have same ski and had same problem. Both bailer tubes in the venturi had fallen out.
    Jul 2004
    Ft Worth Tx
    1,095
    I dont think that is the case with this one as he added water to the hull and saw water leaking at the carbon seal area of the driveshaft but hen again that is another thing to look at. Is it taking on water while riding only or while riding and sitting? If while riding only check the bailer tube connections that they are still on the fittings in back.
  1. Replies: 0
    Last Post: 08-28-2007, 03:01 AM
  2. Exhaust has water leak
    By ADrider in forum Yamaha
    Last Post: 12-10-2006, 07:25 PM
  3. Water Leak and Rattle Noise at idle Ultra 150
    By junglerunna in forum Kawasaki
    Last Post: 09-22-2005, 08:15 AM
  4. Please Help . Water inside a 650 Kawa Engine
    By clydewater in forum Kawasaki
    Last Post: 09-15-2005, 08:32 PM
  5. Water inside a 650 Kawasaki
    Last Post: 09-12-2005, 04:29 PM
