Re: Break-in oil
If you ran it that long your most likely ok. I would make sure to warm it up at least 5 minutes before going to half throttle to make sure that the pistons, rings, cylinders are properly warmed and lubricated. I warm mine up 5 minutes even now I believe it adds a lot of life onto the engine and its not that expensive on fuel.
Make sure you follow the break in procedures that SBT shows and common sense.
This is a bit of topic but I purchased a new Yamaha Wave Blaster in 1996. From the factory the oil pump was tuned rich on purpose after the break-in I was suppose to go back to the dealer and have the pump leaned down. I decided against ever having it leaned since the plugs weren't fouling out I decided that a little extra oil couldn't hurt. The ski ran awesome up till when I sold it recently.
On that theory is why I run 100:1 in my fuel along with the factory oil pump thats on my seadoo. Most pwc engine failures are do to the oil pump stopping working or a hose breaking etc. The 100:1 mixture in the fuel keeps the motor lubed all the time and gives me piece of mind that if the oil pump quits working for whatever the reason that my engine most likely won't blow-up I will see the oil in the bottom of the ski or notice that the ski isn't smoking like normal. I also noticed that sbt says to mix 40:1 in the fuel for the break-in so thats kinda what gave me the idea and its been a good one at least for me.
Joe
Joe
