As it has 300+ Hours I think its time to change the oil filter in the front under the 2 Black air hoses. I,m going to put a small hose pincher on each side of the filter line- Then replace and zip tie the new filter in- then take of the pincher nearest the oil tank- let the oil fill the new filter good and then take the pincher off between the filter and the engine-then fluff the hoses a little were the pinchers were on the hose. Is this an acceptabe way to do this.
Also WHERE is the air going down those 2 Big air hoses in the front of the hull coming from. It appears to suction from somewhere- like the grilled vents on the side under the instrument panel?
