Hello... I am new here, and new to watercraft. I am not new to small engines of all sorts, and I am fairly mechanical. I wanted to buy a machine in need of repairs to get in reasonable, and did a lot of research. I purchased a 97 XP with motor troubles. I believe that I bought it right, so I can do any/all repairs required and still have much less invested than buying one in fair running shape, plus have the benefit of a fresh motor.
This machine would start easily, but showed 150 on the front, and 100 pounds on the rear. I have pulled the top end down, but have yet to pull the pistons from the rods. The rear piston is a bit cooked with the lower ring firmly implanted in the groove. I have not miked the cylinders, but neither has any deep gouging. I am thinking they would bore up ok.
My questions at this point deal with the condition of the lower end. How does one get a real good idea of the condition of the lower end bearings? I am thinking I should have purchased a pump/gauge and pressure tested the lower end before tearing the jugs off to get an indication of seal condition?... When I pull the pistons, I should be able to feel how smoothly the crank rotates... Is that a good indicator?.. The rods don't have excessive sideplay..
I have spent a lot of time reading my manual, and seen a lot of good advice here. I look forward to reading some replies. Thank You! Bob
