Could this also cause the engine to be low on RPM. Mt SLT 750 currently only turns about 6750. It turned 7250 when it was new. I am running an engine I purchased from you 6 months ago.
Polaris 650/750 Fuel pump replacement
Re: Polaris 650/750 Fuel pump replacement
No it did not turn 7250 when new, unless the impeller was changed to a lesser pitch. 6700 is good stock.SBT Tech Support is here to help with your problems.
Yes it's possible you would lose RPM from lack of fuel, but I would expect damage by that point. Do a compreesion check.SBT Tech Support is here to help with your problems.
