Help with water line routing, 96xp-98spx
  • Help with water line routing, 96xp-98spx
    Hello, I need some help making sure that I install my water lines correct on my 96xp to 98spx conversion.
    I need to know the following
    Line coming off the water regulator on the muffler. "Where does it plug into"
    The pisser line going out the back. "Where does it plug into"
    One of the main lines that has the hose connection "T" and then exit's out the hull by the pump. Does this line connect to the engine on the nipples toward the rave valves or the nipple farther away from the valves.
    The second main line. Does this line plug into the nipple coming through the hull that is connected to the pump? And does this line plug into the nipple closest to the rave valves or farthest?
    And last there is a clear line coming off the exhaust exit. I'm not sure where this line plug into. Thanks for all the help.
    Garrett
    Re: Help with water line routing, 96xp-98spx
    www.hlsm.com - full online microfiche.
