Re: 96 GTX Fuel Issues
Obviously, use a can of carb cleaner and the red tube spout to blow through all openings and orifices so that you can see the fluid come out the other side. Then use an air compressor and blow through all openings and orifices.
Try pressure testing the fuel system once you get it back together and gas in the tank.
Do as Bill suggested and check out the fuel valve.
Good Luck!
Good Luck!
