1997 gtx 787 rotax
Can anyone tell me if I have a problem with the Oil Injectors on my Intake Manifold. I installed the Oil Pump and put new oil lines from the pump to the injectors. After hooking the lines to the Injectors and before hooking them to the pump, I tried to blow air through the Injector to see if they were clear (did not use compressed air just blew in the tube) I was unable to get air to blow out the injector, they felt plugged. Should I be able to get air through or is this normal?
Your imput as always is appreciated!!!!
