How can I tell if the charging system is working on a 01 XL700?
While doing some water testing the battery suddenly would not crank the engine. Probably started 8-10 times, run less then 10 minutes. After charging the battery and restarting, I disconnected the battery and the ski continued to run. Does this mean the generator is putting out OK and is this a safe (wont blow anything up) test of generator?
