Well, did the first lake test today after fresh complete rebuild. Put the carbs at factory specs according to Seloc. Idle is OK, get it to 25~3000 RPM's, it will crap out unless you give it choke, then if you ever get it to full throttle, working the choke, it will scream. (don't wanna do that yet, new engine) Has new 780 fuel pump with 3 outlets. Is this a hi or low speed adjustment, fuel restriction?
Inquiring minds........
Jim
Jim
