Just installed an SBT 787 in the ski and I'm ready for break-in. 2 questions:
- If I did not remove the TPS from the throttle body, do I still need to re-calibrate the MPEM?
- I ran the ski for a few minutes on the hose to make sure it would run once I got it to the lake and it started fine. I had to feather the throttle a bit to keep it running and it would not idle on it's own. Is this normal for a fresh engine or will the idle speed ajustment cure this after I adjust it on the water? Thanks
