I have a '95 XP800. Since I have it apart for a rebuild I found the drive shaft could use a little attention.
Corrosion has pitted the surface of the shaft where exposed outside of the hull and, although the seals are not leaking, it could use resurfacing at the thru hull seals.
My questions:
Is there a min. dia. for the shaft at the thru hull seals, and, if I were to have the shaft "cleaned up", is there a min. dia. for the shaft?
My questions:
