I have 2 2004 XLT 800's, :emoticont 35 hours or so on each,,,they run great:emoticonc ,,,with one exception ,,,one of them has started to stall more than once in a while at idle in the water ,,,a simple blip of the throttle will clear it out but returns shortly...I have noticed that when I open the fuel tank cap on this wave runner there is some air pressure released...the other wave runner does not...I can keep it idling fine with just a constant touch of the throttle so i turned the idle set adjusment up a little to compensate..seems to still have the same problem but now at a little faster idle.
I will investigate the vent check valve & water seperator today for blockage. Also, i guess I need to verify the sound I hear from the gas cap is air rushing out or rushing in. :emoticonn
