1999 polaris genesis i w/ficht wont run
  • 1999 polaris genesis i w/ficht wont run
    Just bought this pwc used it for 3 days on third day, was putting it on the trailor would not start back up, wouldn't turn over, found looose battery cable, tightened them down still wont start, changed plugs, perfect engine compression, has spark, will fire up with carb cleaner then dies right away,thought i had water in the gas but drained and cleaned everything but still wont fire up on its own... any help would be greatly appreciated email me if you know a good mechanic in southeastern michigan near lake st. clair
    Re: 1999 polaris genesis i w/ficht wont run
    first stop using carb cleaner or you will need a new engine . BUT seenign it starts with cleaner then dies , your fuel system needs to be cleaned out or you need a fuel pump . could be somthing else but no one can tell without looking at it .
