Results 1 to 8 of 8
  1. #1
    Joined
    Jul 2001
    From
    Tennessee
    Posts
    26
    Post
    My 98 GP1200 took on alot of water yesterday shortly after putting it in the water. Today I filled the hull up with water and I can see it coming out on the back of the intake grate. I believe it is coming out where the driveshaft goes through the hull but I am not 100% positive. How can I tell for sure or is there simply no other way for water to come in at that spot? What can I do to repair that leak? Thanks again.
  2. #2
    Joined
    Feb 2001
    From
    Clearwater, FL
    Posts
    7,358
    Post
    You need to remove your entire pump assembly, and reseal it to the hull.
  3. #3
    Joined
    Jul 2001
    From
    Tennessee
    Posts
    26
    Post
    So its not like a SeaDoo where there is a seal that goes bad? Just asking for personal knowledge. Are there any tricks to removing the pump? Any special tools I need? Anything that should be done while I have it apart? Thanks.
  4. #4
    Joined
    Feb 2001
    From
    Clearwater, FL
    Posts
    7,358
    Post
    That particular model has a whole pump assembly, much better than just a flimsy seal. It's pretty straightforward, no special tools needed, although you really should get a shop manual if you're going to work on a ski yourself.
  5. #5
    Joined
    Jul 2001
    From
    Tennessee
    Posts
    26
    Post
    The manual is the first on the list, thanks for the info!
  6. #6
    Joined
    Jun 2001
    From
    Houston, TX
    Posts
    24
    Post
    While we are talking about water in the hull...
    I can't EVER seem to remember to put the plugs in before I put the boat in the water. So far I haven't sunk it and for that matter, I haven't really seen much water come out when I pull it up on the trailer.
    What's up with that? I expect to sink some day!
    - dan
  7. #7
    Joined
    Feb 2001
    From
    Clearwater, FL
    Posts
    7,358
    Post
    I expect the same.
  8. #8
    Joined
    Aug 2001
    From
    Texas
    Posts
    12
    Post
    Someone, smarter than I, once suggested, to tie the plugs to your handlebars. If that doesn't remind you......then you'd better invest in some SCUBA gear! [img]smile.gif[/img]
Thread Information
Users Browsing this Thread
Similar Threads
  1. Water route???
    By pwgsx in forum Sea-Doo
    Last Post: 11-08-2005, 01:20 PM
  2. water in the hull
    By bge20021@netzero.com in forum Sea-Doo
    Last Post: 09-04-2005, 02:36 PM
  3. Water leakage at driveshaft thru hull
    By Dorman McLamb in forum Kawasaki
    Last Post: 07-24-2004, 11:58 PM
  4. THE AGE OLD SUBJECT OF WATER INTRUSION
    By bamboo in forum Sea-Doo
    Last Post: 10-21-2003, 12:46 AM
  5. interesting theory on water injestion on 951
    By BEECHFRONT in forum Sea-Doo
    Last Post: 09-13-2001, 08:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
