SBT Tech Support, typically how long does it take to get a machined RV cover and valve? I rechecked the clearance on mine and got 0.015-0.017 using the solder method. I have been having a hard time restarting the ski when it is warm. The RV cover looks fair, I've attached a picture, but you can feel grooves as you drag your finger nail across the surface. NOt quite as deep as a phonograph record surface but similar. I checked the Rotary Valve surface and it appears good (147 degree) but I might as well replace it to, if I'm going through this much trouble.
Can you tell me if an exhange is available, the number on my RV cover is 911.165?
Also, does an exchange include both O-rings (one on each side)?
Thanks
Thanks
