In order to get to my fuel baffle my shop manual for my 98' gsx limited tells me I have to remove the steering assembly... I'm wondering if anyone out there has done this before and exactly how far I need to go as far as the manual tells me? I've seen some other posts that just say to remove entire steering pod itself by removing those 4 bolts that you see holding the steering unit down when you lift the hood up. Do I just have to remove those 4 bolts to get to the baffle? Or do I need to also remove the steering cable, etc...?
I've also seen posts telling people to go through the hood and pull the gas tank toward the front of the sea-doo in order to get to the baffle? What is the easiest way? Thanks
