Results 1 to 7 of 7
    Jun 2005
    47
    Default should i grease it?
    I dont know much about seadoo's. But the other day i was looking under the seat and found a grease fitting near where the shaft goes through the hull? First am i correct that it is where i should grease? if so how much grease should put in
    Mar 2004
    Bright, Indiana
    375
    Default Re: should i grease it?
    Grease after every ride. The grease forces the water out of the bearing. Just enough grease until it starts to ooze out of the engine side of the bearing. Check the PTO also for a grease fitting and shoot enough grease in until the rubber boot starts to expand.
    "I'm doing the best that I can according to my current awareness!"
    Jun 2005
    Melbourne, Australia
    249
    As Danny said....GREASE IT!!
    If you don't then water will get into your drive shaft bearings and they will seize up. I do what Danny said and then run the engine for 30 secs afterwards to keep the bearing in good nick. Don't overgrease, only till grease starts to come out. You just use a grease gun and make sure you use the correct grease for your jetski. I have a 95 XP and use Morrey's Big Foot grease. Please go to your local service place and ask them what to use though-don't rely on what i am using because i am going on the advice of someone else:emoticont
    May 2004
    Springfield, Oregon
    436
    manuals say like every 10 hours. I shoot two shots in there every other ride, which is more frequently than 10 hours.
    Jun 2005
    47
    okay i just gave each spot a couple squirts of grease runs better i think...but after running it on water after a minute or two it will bog down and then when i restart it, it will only run for a coulple seconds. gotta keep on giving it gas for it to run. is this normal? could the problem be old gas or is it something else?
    Nov 2003
    Glendora, CA
    6,846
    Probably needs some attention to the carbs, needle and seat and fuel selector valve. No it is not normal, and greasing it should not change the way it runs.
    May 2004
    Springfield, Oregon
    436
    has this ski been sitting for a while, like over the winter, just before noticing that it now won't run good? (carbs) Or, did it just happen? (fuel lines/selector/pump)
  1. 04 FX HO Pump Grease
    By dundeels in forum Yamaha
    Last Post: 02-10-2005, 03:36 AM
  2. two grease fittings
    By my2001s2000 in forum Yamaha
    Last Post: 07-31-2004, 05:51 PM
  3. Grease Fitting Location (94 Wave Raider)
    By CROWBAR-TN in forum Yamaha
    Last Post: 05-07-2003, 09:51 AM
