hello guys im here today to obtain some help or info .
i own a 2001 kawasaki ultra 150. it runs great since i got it a year ago i have used it about 5 or 6 hours total since then. flipped it the first time and me being a begginer i let it sit a few hours . i had the sense to take it to the jet ski rental guy around the corner from the bay . he charged me two fifty and took the plugs out some starting fluid and got the water out little by little but it works great since then . now the problems i have are always different first we were at a salted lake and after a few hours it started to over heat and will run but will start to blow smoke from impeller and water blowout on the side . i let it cool off and realised smoke was coming out of the engine compartment the wires running from the speed sensor on the left rear was frying i emmidietly poured water on it to cool them of and then unplugged it from the main harness . now i i repaired the burnt wires and the speedometer on the cluster does not work anymore . still runs great and now recently these last few times i have been riding it. seems to always get something stuck in the propt is this normal on this type of ski . and what upgrades would any of you recommend thank you . please go easy i am a begginer with a jet ski , thank you
