Results 1 to 7 of 7
    Jun 2005
    Qubec, Canada
    3
    Default MPEM, CDI testing procedure (1994 XP-650
    Hi, sorry for my bad english ! I'm trying to find a way to test the MPEM, the CDI and the magneto on this 1994 XP 650.
    It is my friend's Seadoo and I'm trying to help him.
    The engine starts but stalls as soon as we crack the throttle. I cleaned the carbs but they were not durty. I didn't change any parts !
    When I was testing it (with flushing hose), the starter was weak. After some testing, I fund a black negatif wire, in the plastic box, that was melted to the output stud of the starter solenoid (starter side). So when I was starting the engine, I was sending 12 Volts power to the ground circuit of almost every boxes... Even the isolator is melted on the black wire of the magneto wiring harness.
    That's why I'm looking for help for testing every thing with an ohmmeter. I do have some Bombardier shop manual but only for 1996 and up. I also have a Clymer manual but testing are not complete...
    Any help will be greatly appreciated !
    Pierre
    Nov 2003
    Glendora, CA
    6,846
    Default Re: MPEM, CDI testing procedure (1994 XP-650
    This would be the same as if you reversed the battery cables. Typically, that melts wires in the harnesses. I doubt you hurt the stator or the CDI. Maybe the mpem and some wires.
    Jun 2005
    Qubec, Canada
    3
    Thanks for your answer, if I ever need an MPEM, do you have some used one ? and how much do you want for ?
    Thanks, Pierre
    Nov 2003
    Glendora, CA
    6,846
    I might have a 1994 XP MPEM.
    Have you tried replacing the relays that plug into the MPEM?
    Jun 2005
    Qubec, Canada
    3
    No I haven't !! I saw some fuses but I didn't see those relays. I will look at that tomorrow.
    I will let you know if my friend wants some parts or maybe he will bring it to the dealer...
    Thanks, Pierre
    Sep 2020
    Panama
    116
    Default инвестиционные проекты татарстана 2020
    Как известно, прямые инвестиции — наиболее гибкий вид финансирования развития бизнеса, доступный тогда, когда остальные источники не могут быть использованы. Сотрудничество фонда с компаниями может строиться различным путем: фонды могут выступать как отстраненными финансовыми инвесторами, так и участниками бизнеса, активно вмешиваясь в операционную деятельность. Private equity фонды, как правило, выходят из проектов в течение лет, получая в этот период доходность на уровне % годовых. По оценке экспертов, прямые инвестиции — сравнительно дорогой вид инвестиций, которые накладывают дополнительные обязательства на компанию. Например, фонды снижают риски, подписывая соглашения, противостоящие размыванию капитала, получают право на информацию, право первого выхода из проекта, вето на крупные транзакции. новости про компании
    Apr 2020
    Moldova
    1
    Default Naked hot webcams model online porn char
    says:Just check this out, adult webcams in public for free!
  1. 1994 Polaris SL750 and 1992 Yamaha VXR 650 F/S in NJ
    By Johnny in forum PWC's For Sale
    Last Post: 07-28-2005, 09:46 AM
  2. 1200 non-PV CDI Testing possible?
    By Deadhead in forum Yamaha
    Last Post: 07-10-2004, 07:23 PM
