Hello,
I resently rebuilt my 96XP and in the process of breaking it in. But after the 2nd tank of gas I noticed a loss of power and could only get about 40mph out of it. I ran a compression test and found that the mag cylinder had 100 psi and the pto cylinder had 160 psi. So I pulled the motor and I am runnig a pressure test. I have made up a block off kit for the carbs and the exhaust. Do I have to block off anything on the rave valves?
When I add about 5 lbs air to this motor I hear air leaking from the rave valves and when I take off the rave caps the air blows the spring off the rubber boot. Could I have a rave problem, could that be the cause of my low compression problem? This happens only on the cylinder with the low compression.
