I just purchased 2 identical 900 zxi's, one runs normal and is in good condition but the other ski will not start or shall i say will not power up. I have interchanged the complete electrical box (inclds. starter relay,coils,cdi ignitor, etc.) from the good ski to the bad one and still no power to the system, in addition to installing a new battery, I have interchanged the starter motor, orange magneto key switch and starter button on handle bar, but still no power. fuses are fine (brought the whole electrical box from good ski to bad ski), only thing that i have not interchanged is the wiring harness, can anyone please tell me what else to check or what could be the problem. at this point i would be happy to see the indicator light go on or at best, the starter to crank. oh yeah, i cleaned the ground contacts as well. what could be causing this ski to not power up? please help!:emoticonb
1996 kawasaki 900 zxi electrical problem- wont power up!
Re: 1996 kawasaki 900 zxi electrical problem- wont power up!
If you dont have a wiring diagram I usually start at the switch and start stop button and see if you have continuity to the computer box. also check to see if a plug connector is disconnected and or corroded.
I had A same problem with my ski. There ended up being no problems with any part. if you look at the front of the grey electrical box there are to sets of wires coming in one is the stator and the on off electrical wire. the problem was the connector was not making a good connection. the connector it self did not look bad but it was. i do not know if this is your problem or not but the symptoms were the same.:)
Originally posted by brad2510I had A same problem with my ski. There ended up being no problems with any part. if you look at the front of the grey electrical box there are to sets of wires coming in one is the stator and the on off electrical wire. the problem was the connector was not making a good connection. the connector it self did not look bad but it was. i do not know if this is your problem or not but the symptoms were the same.:)
The wire that i am talking about is the wire that comes from the stator assembly, and goes th the grey box. that might be the reason that the good box no longer works in the good ski. Just trying to offer suggestions. Electrical Problems Are such a pain in the ***. They are so hard to pin down and find the real cause. As far as buying a new ski I am going to get rid of the zxi and get a yamaha gp 1300. First they are very reliable if they don't break who cares how easy it is to work on. the second thing it has going for it, also easy to work on. My friend that i ride a good bit with would not trade it for the world. good luck.
