Results 1 to 2 of 2
    Jun 2005
    Melbourne, Australia
    249
    Default Opened 720 engine up-no crankcase gasketseal!
    Hi everyone,
    I just finished pulling apart my engine (720 rotax) and was surprised to see that there was no gasket/sealant or anything between the 2 crankcase castings. The only thing i found to fill any possible air gaps was oil! Is there supposed to be some kind of gasket there?
    If there is supposed to be a gasket i am even more surprised-the engine was still running well and it's in excellent condition on the inside (no marks on the cylinders, crankshaft not out of spec, etc-i pulled it apart to do a piston change, replace the crankshaft seals and generally do some preventative maintenance. The reason for this is i have a factory pipe on my ski and didn't want to wait till the engine blew up.
    Has anyone had a similar experience with the no gasket thingy?
    Thanks.
    21,545
    Default Re: Opened 720 engine up-no crankcase gasketseal!
    I assure you there was sealer there. Factory engines have a very thin coating of case sealer that would appear to be an oil like substance to someone unfamiliar to them.
  1. Replies: 0
    Last Post: 01-05-2007, 03:04 AM
  2. SBT 720 engine
    By virtualzoo in forum Sea-Doo
    Last Post: 07-28-2006, 12:37 AM
  3. Engine Warranty/Customer Service
    By Lance Riddle in forum The SBT Experience
    Last Post: 08-17-2005, 01:36 AM
  4. SBT 720 Engine
    By hurrcane201 in forum The SBT Experience
    Last Post: 10-19-2001, 03:45 PM
